.NET ActiveX in XUI dialog
ebisaill
------_=_NextPart_002_01C65718.1D9ACD45
7 REPLIES 7
Hi Eric--
We use a .NET control for editing MathML expressions in
Epic. The integration is managed by a C# COM wrapper that makes the control
masquerade as an ActiveX control, which Epic can then load from a
script.
One thing that might work for you: instead of trying to
embed the control in a XUI dialog, can you make the .NET control create its own
dialog? If so, then you can invoke it from JScript or VBScript, pass it info
from Epic, let it do its thing, and then get the result before you close it.
That is how our MathML control works, and it may be why we haven't had the kind
of problems you mention.
One caveat though, our current implementation is not
compatible with .NET 2.0, and I haven't had a chance to update it yet to see if
we can make it work with .NET 2.0. It may be that it's much more difficult to do
this sort of thing with the new version of .NET.
(For my money, .NET is way more trouble than it's worth.
Give me Java any day of the week!)
class=252542614-03042006>
--Clay
Sent: Monday, April 03, 2006 7:14
AM
To: adepters@arbortext.com
Subject: .NET ActiveX in XUI
dialog
Hi
everyone,
Was anyone
here successful in embedding a .NET ActiveX in an XUI dialog? I was able to do
it for non-.NET controls but still no luck with .NET.... I keep reading that
.NET no longer supports the creation of ActiveX controls but I was wondering if
anyone here was able to ultimately embed a .NET component in a XUi dialog? Any
help/tips would be appreciated.
EB
<tr>
<td colspan="2">size=2>Eric Bisaillon
Business Analyst / Analyste
d'affaires
Business Support, Application Services / Appui des activités
applications et services
Information Management Branch / Direction de
la gestion de l'information </td></tr>
<tr>
<td colspan="2">Department of
Justice Canada / Ministère de la Justice Canada
275 Sparks Street, SAT
11031 / 275, rue Sparks TSA 11031
Ottawa (Ontario) K1A 0H8
</td></tr>
<tr>
<td colspan="2">tel. / tél.: (613) 946-0393
fax / téléc.: (613) 941-5201
href="mailto:ebisaill@justice.gc.ca">eric.bisaillon@justice.gc.ca
</td></tr>
<tr>
<td></td></tr>
<tr>
<td align="left" width="132"></td>
<td></td></tr></table>
Hi Clay,
Thanks for the quick response. We actually have
quite a good amount of .NET code that we invoke through Epic with COM that have
their own dialogs and it works well but in this situation, I was looking at
embedding it in an XUI dialog to try and take advantage of the new capabilities
in 5.1 and use that XUI as a toolbar and really integrating that .NET component
in the Editor (as a toolbar) instead of a modal dialog (our other .NET
components).
Maybe if I can figure out a way to call COM
components that draw non-modal dialogs but I don't know if that can be done,
maybe with the Epic .NET PIA, any experience using that here
Thanks again,
Eric
Sent: April 3, 2006 10:34 AM
To:
Subject: RE: .NET ActiveX in XUI
dialog
Hi Eric--
script.
--Clay
AM
dialog
Hi
everyone,
Was anyone
EB
<tr>
d'affaires
<tr>
</td></tr>
<tr>
</td></tr>
<tr>
<td></td></tr>
<tr>
Ah, I see what you're up to. Sorry, but I'm afraid my
original message has exhausted my knowledge of .NET and how it works with Epic,
so you'll have to find someone smarter than me to help figure this one out.
Sent: Monday, April 03, 2006 10:10
AM
XUI dialog
Hi Clay,
components).
Thanks again,
Eric
To:
dialog
Hi Eric--
script.
--Clay
AM
dialog
Hi
everyone,
Was anyone
EB
<tr>
d'affaires
<tr>
</td></tr>
<tr>
</td></tr>
<tr>
<td></td></tr>
<tr>
Hey Clay, don't worry about it, thanks foryour input.
I'll let you know if I find a solution that works... (Why would MS remove
support for ActiveX components... err....)
Eric
Sent: April 3, 2006 2:14 PM
To:
dialog
AM
XUI dialog
Hi Clay,
components).
Thanks again,
Eric
To:
dialog
Hi Eric--
script.
--Clay
AM
dialog
Hi
everyone,
Was anyone
EB
<tr>
d'affaires
<tr>
</td></tr>
<tr>
</td></tr>
<tr>
<td></td></tr>
<tr>
Probably to make it harder for us to avoid upgrading to
Vista when the time comes....
Sent: Monday, April 03, 2006 1:29
PM
XUI dialog
Eric
To:
dialog
AM
XUI dialog
Hi Clay,
components).
Thanks again,
Eric
To:
dialog
Hi Eric--
script.
--Clay
AM
dialog
Hi
everyone,
Was anyone
EB
<tr>
d'affaires
<tr>
</td></tr>
<tr>
</td></tr>
<tr>
<td></td></tr>
<tr>
Well, ActiveX was based on COM, so with .NET being the
"next great thing" which replaces COM... In any case, I think Clay's
initial suggestion might do the trick. That is, use C++ (ok, Clay said
C#... did you mean that, Clay?) to create an ActiveX "control" that just passes
all the appropriate calls on to your .NET component via COM
interop.
There might be a way to achieve this directly using
COM interop without having to do the C++ wrapper, but that's beyond my
experience. If you wanted to try, though, I'd suggest starting with an
ActiveX control that you know will work in your XUI and look at it using the
OLEView tool that comes with Visual Studio 6. That will let you see which
COM interfaces are implemented by the control. Then, you just need to make
sure that your .NET component provides those same interfaces. This will
probably not be very straightforward, but it seems like it should be
possible.
class=428313218-03042006> This is a fairly interesting project, so I'll be
interested to know how it goes. Contact me directly if you run into
problems, if you like.
Brandon Ibach
Lockheed Martin Space
Systems
Cape Canaveral, FL
321-476-7051
Hi Brandon--
I did in fact mean C#, though to be perfectly honest, I
find C# and C++ to be of about equal distaste. And we didn't write the C#
wrapper, the third-party guy who develops the control wrote it. Unfortunately,
now that Microsoft has made it more difficult to do such things (apparently), he
has washed his hands of the COM wrapper. So, against my better judgment, it
looks like I'm going to have to sit down and actually learn some of this
Microsoft stuff.
class=553455118-03042006>
--Clay
Sent: Monday, April 03, 2006 1:40
PM
XUI dialog
interop.
possible.
Brandon Ibach
Systems
Cape Canaveral, FL
321-476-7051
