OID within a selection
jsulak
Hello Adepters,
Quick question: Is there an ACL function (or AOM method) that can tell
me if a particular oid is within the current selection? Seems like this
should be built in, but I can't find it.
-James
I don't think there is such a built in method. But you could use oid_treeloc on selection_start and selection_end and the particular oid you are interested in. Walk down the strings doing compares at each level.
John Dreystadt
Software Development Director
Arbortext - PTC
734-352-2835
jsulak
(To:jsulak)
Thanks, John. I'll take a look at that.
-James
jsulak
(To:jsulak)
Based on an off-list suggestion from Brandon, I came up with this:
function oid_in_selection(oid) {
if (!selected()) { return 0; }
$o1 = selection_start($p1);
$o2 = selection_end($p2);
$offset_from_start = oid_offset($o1, $p1, $oid, 0);
$offset_from_end = oid_offset($o2, $p2, $oid, 0);
return ($offset_from_start >= 0 && $offset_from_end <= 0);
Seems to work based on the limited testing I've done so far.
-James
Cool! Thanks for posting the solution, James.
