Page Numbering for a Blank Page in XSL-FO
  • March 23, 2010
  • 4 replies
  • 1047 views
I'm working on a new XSL-FO stylesheet. I have my sections to always start on an odd page which will produce a blank page if the previous section ends on an odd page. My problem is that I need to the page number to show the blank page. So if the last page number in the section is Page 3 the page number should display as Page 3/Page 4 Blank.
I've tried fo:marker with fo:page-number-citaition but can't quite get the result that I need.
If anyone has successfully done this I would appreciate any help.
Sarah
    I am using the DoD's XSL-FOs and they have reduced theirs to something like "Page-5 / blank" - perhaps until they get the page number count working (they currently have it commented out 🙂
    <fo:marker marker-class-name="blank-page">
    <xsl:text> / </xsl:text>
    <xsl:text> blank</xsl:text>
    </fo:marker>
    Then, in <fo:block><fo:flow> they reference <fo:marker marker-class-name="blank-page">
    This is in pageset-templ if you have access to the Army SGML/XML Registry & Library at asrl.com
    John T. Jarrett CDT
    Sr. Tech Writer, Tech Pubs, ILS, Land & Armaments/Global Tactical Systems
    T 832.673.2147 | ext 1147 | -<">mailto:->
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
    Thanks so much for your response. At least I know its not my coding. This is exactly what I am using just trying to generate that page number. I was wondering if you could just add 1 to the last page number but since you can't save fo:page-number or fo:page-number-citation into a variable I haven't been able to get that to work.
    I'm going to leave it as is.
    Thanks again,
    sarah
    Sometimes old SGML technology like FOSI still does some things better than XSL-FO.
    AMEN!
    Sarah
