Prespace on paragraph after table
ebenton
It looks like the <date> tag is right after the <table>. What
formatting is on the <date> tag?
Assuming FOSI and not some other weirdness:
Check your paragraph to ensure that it has a text break. Prespace is
not supported for in-line elements, or as it is phrased in Help: A text
break must appear in the charlist of each e-i-c that is formatted using
prespace or postspace.
From Arbortext Help: If two elements with identical adjacency priority
values (other than force) have identical preferred values, the maximum
and minimum from the first will be used.
-Andy
\ / Andy Esslinger LM Aero Tech Order Data
_____-/\-_____ (817) 279-0442 Box 748, Mail Zone 4285
\_\/_/ (817) 777 3047 Ft. Worth, TX 76101-0748
What Andy said, but as Ed asked, what is the formatting on <date>? The
textbreak may be required on the <date> element as well, since it is the
first element following <table>. In fact, if the amount of prespace you
are setting should only apply to a <date> following a <table>, then you
need to set the prespace on <date>, not on <paragraph>.
When developing a FOSI it is usually necessary to provide at least a
textbreak for parent elements like <date> in this case. Some
inheritance may also need to specified for fonts, leading, indents, etc.
I often find that when an element's formatting isn't displaying or
printing as I expect it should, I've missed specifying at least a
textbreak on the parent or an earlier ancestor.
Cheers,
David
David S. Taylor
Project Manager, Structured Information
Institute for Research in Construction
National Research Council Canada
Bldg. M-23A, Room 239
1200 Montreal Road, Ottawa, ON K1A 0R6
