Hey,
We came across a symbol that I can insert into Epic with no problem, but
it does not seem to show up in the published output. The symbol is the
approximation symbol, entity ≈. Its hex entity is ≈. If we
convert the character entity into its numeric entity, it works fine.
There are other symbols that work fine such as those with character
entities ≠ ≡ ≤ ≥. I know I could use the properties
set entityinputconvert=on and set writenonasciichar=numref within Epic,
however, these cause an issue with some other functionality we have.
Can these be used specifically in E3 or is there something else specific
to E3 that can be done? We are on version 5.1M (That is why I still
call it E3)
Craig
