I have a query regarding printing in Arbortext Editor 5.3.
When I reduce text size to e.g. 84% and print, the tags are reduced in size but the text stays at 100%.
Is there any way to reduce the text size when printing?
Thanks.
Thank you to all of you for such a quick reply. I started with the simplest suggestion and it worked!
Inserting set editfontpercent=84 from the command line and then printing the text gave me a printout with reduced text size and reduced tag sizes. Not sure why reducing the text size using the small "A" on the menu did not work for printing.
This will go a small way to saving the rainforests with more text on the printed page 🙂
