Publishing Rules
naglists
Publishing Rules
Has anyone had any luck creating publishing rules for individual documents
and controlling the output directory and file name? Specifically, my
authors want to direct output to a specific folder and they want the
filename to be the name of the XML file. (Most important, I think, is the
filename.)
I can see (although I didn't try to change it) that there might be some
control using %n %u and %s but none of those values reference the source
XML instance's filename.
I'm wondering if there are options/parameters I can specify on the Advanced
tab that would do this. I can't find anything helpful in this regard in the
help, though.
Paul Nagai
By "individual documents" I do not mean one rule per XML instance. I just
mean rules that would be used for a class of XML instances but the output
would be a single document.
