Question about OIDs and selected content...
JasonBuss
Just wondering if anyone else has tried this,
Is there a method in ACL for getting the OIDs within a selection (i.e.
to get the oids from a selection highlighted by the author?)
Working on some legacy conversion trying to convert SGML singletons that
were included into every element declaration into corresponding
attribute values for all valid elements in between the singletons. I am
beginning to think there is no good automated solution...
-Jason
Never Mind. I just found the selection_start/end funcs.
-Jason
Hi Jason,
Sounds like you don't need it, but I think this should work (this was similar to a previous question I've asked). get_selection_oids() should return an array of all the oids in the selection. The first while loop bothers me, but so far so good:
function get_selection_oids($oids[]) {
if (!selected()) { return 0; }
local $o1 = selection_start($p1);
local $o2 = selection_end($p2);
local $cur_oid = oid_forward($o1);
while (!oid_in_selection($cur_oid)) {
$cur_oid = oid_forward($cur_oid);
while (oid_in_selection($cur_oid)) {
$oids[high_bound($oids) + 1] = $cur_oid;
function oid_in_selection(oid) {
$offset_from_start = oid_offset($o1, $p1, $oid, 0);
$offset_from_end = oid_offset($o2, $p2, $oid, 0);
return ($offset_from_start >= 0 && $offset_from_end <= 0);
-James
