SYSTEM Identifier
The DTD that we are using is loaded on the server. Our publishing engine that process the XML file needs the DTD to be loaded on the server and wants the server path in the SYSTEM idenitifer of DOCTYPE. Something like below
rather than
Can someone guide me which option in ArborText should be changed so I have XML file pointing to update the DTD on server and have the server path updated in SYSTEM Identifier field.
Karthik
