Sample XML file that uses schema descript.xsd
cleccese
Hi, can someone share a sample XML file that uses the descript.xsd schema? I need something to start building a style sheet and I don't have any XML files. I haven't been able to find it myself.
If you want to xxx out your data, at the command line type
replace(".","x",0x2004)
Thanks!
So, "descript" is an S1000D data module type. The easiest way to get sample material is to search for the S1000D bike sample and download that. You need to know which issue (version) of S1000D you are targetting and download the correct sample set.
Side note: PTC has already developed stylesheets for many S1000D data module types. You could save yourself time by reusing those.
OK thanks Gareth! I downloaded the bike sample, but where would I find those stylesheets?
RayStachowiak
(To:cleccese)
For the .sty Styler style sheets, check with PTC but may they are part of their S1000D application package.
