Securing a PDF with master password BUT allowing commenting in Arbortext
LV_9577874
Hi Arbortext Community,
I'm trying to secure PDF documents with an appcf file using the security element, but I want the user to be able to comment on the PDF. The issue is that, somehow even setting noAnnots="no", I keep having the Comment Creation as Not Allowed in the PDF protection menu.
Does someone know how to solve this?
Here my appcf file XML:
<?xml version="1.0" encoding="UTF-8"?><!--Arbortext, Inc., 1988-2023, v.4002--><!DOCTYPE APPConfig PUBLIC "-//Arbortext//DTD APPConfig 1.0//EN" "appconfig/appconfig.dtd"><APPConfig version="1.0" xmlns="http://www.arbortext.com/namespace/APP/APPPrinterConfig"><Print><PageConfig bleedAreaBottom="4mm" bleedAreaLeft="4mm" bleedAreaRight="4mm" bleedAreaTop="4mm" bleedString="" cuttingGuideOffset="1mm" cuttingGuideSize="9mm" cuttingGuides="inherit" registrationMarks="inherit"/><PDFPrinter><OutputRange endPage="-1" startPage="1"/><PDFMode color="document" defaultLanguage="" fastWebView="no"/><Compatibility layers="yes" tagging="inherit"><PDF level="1.7"></PDF></Compatibility><ColorProfile defaultCMYK="" defaultGray="" defaultRGB=""/><Images epsDPI="600" linked="original"/><Compression compressText="yes"><MonochromeImages downsampleDPI="300" downsampleMode="off" downsampleThreshold="450" type="ccitt4"/><GrayscaleImages downsampleDPI="150" downsampleMode="off" downsampleThreshold="225" quality="med" type="auto"/><ColorImages downsampleDPI="150" downsampleMode="off" downsampleThreshold="225" quality="med" type="auto"/></Compression><Fonts subsetPercent="100" subsetting="yes"/><Open bindingLtR="yes" displayTitle="yes" interface="showAll" magnification="default" openOnPage="1" pageLayout="singlePage" show="useNone" window="fitWindow"/><Security masterPassword="master-test" noAccessible="no" noAnnots="no" noAssemble="yes" noCopy="no" noForms="yes" noHiresPrint="no" noModify="yes" noPrint="no"/><DocumentProperties></DocumentProperties></PDFPrinter></Print><Format><Passes compareMode="stability" maximum="6" minimum="2"/></Format><DocumentProperties></DocumentProperties></APPConfig>
Try using: noModify="no"
LV_9577874
(To:VladimirN)
But the user shouldn't be allow to modify without a password.
LV_9577874
(To:LV_9577874)
We were unable to solve this issue.
The goal is to forbid modifications but allow commenting.
Based on PTC documentation, this should be the relevant appcf configuration:
<Security masterPassword="xxx" noAnnots="no" noModify="yes" ...... />
However from our testing, the resulting pdf does not allow comments.
Perhaps noModify=yes overrides noAnnots=no because comments are considered modifications?
We are using Arbortext with Styler 8.2.2.0.
