Hello Kim, as you mentioned there is currently no direct function or entry in the select dialog, that enables you to do so. However, if the layer you want to select all elements in is the active layer, you can click on the button with the eye symbol in the layer window. This makes all other layers at once invisible (except for the background layer). Then you can press CTRL+a and all elements and objects on this particular layer are selected. Please note that regarding layer access there are other functions which are useful as well: - Export of layer(s) - Import of layer(s) - The layer functions in the context menu of the layer window (Dopy, paste, duplicate, ...) - Drag & drop of layer(s) And access through macros as well. regards, Christian
