Styler 6.0 m010: How do I edit a <floatloc>? I can't find it in Styler
naglists
I can see it if I export a FOSI, but it is not in rsrcdesc that Styler
let's me edit.
Can I overwrite it by adding it there?
Specifically, I need to edit how my repeat_titles float formats.
Paul Nagai
What type of edit do you need to do?
Adjust postspace.
Add a ufe to the repeat titles characteristic. Add it after it sets the repeated title. Put a negative post space on the ufe. Just did this recently and it worked very well.
That didn't work, but it led me to try the same thing with Offset which I
got to work (ultimately with a Set, not a ufe. Thanks!
To be fair, I am working with a Stylersheet originally coded in 5.1 or 5.0
and upgraded to 5.3 and again to 6.0 (with a possible stop at 5.2, too, I
just can't remember anymore) so the Title element is completely made up of
FOSI source edits ... oh to be able to refactor ... 😕
