Table exceeding 5 rows not showing
Partner
I have a table configured that uses XPath to show text content.  It works perfectly until I hit the count of 6 rows, at that point it is no longer showing the table.
Here is the styler before text configuration. Screenshot 2025-05-20 114240.png
Here is the expected result within the editor after applying the changes.
Content properly showing with  5 rows.Content properly showing with 5 rows.
Now, with six rows (Xpath values for Row #6 are the same values than our previous row #5). The content in styler is like below. Table with 6 rows in the styler.Table with 6 rows in the styler.
And below the empty table result that I get.
Table content NOT showing anymore.Table content NOT showing anymore.
Do you have any explanation ?
Partner
(To:manpsingh)
I have tried all this, but it looks like there is a limitation:Screenshot 2025-05-20 131955.png
If I don't use generated cells and showing elements without using XPath, everything is fine.  BUT, I need to combined different values and at that point (as soon as one cell uses generated text), nothing shows.
manpsingh
(To:Partner)
Hello Dear,
Hope you're doing well. Please review below help center topic for table xpath.
Custom Tables - Cells Category
Generating Custom Table Cells via XPath
Manpreet Singh
Partner
(To:manpsingh)
