To Fetch PTC server system Attributes in Image element in XML
rr-3
7-Bedrock
twowaymetadatarule doesnt support for graphic object ,but PTC Server system attributes can be pulled into XML documents via ACL
Below is the Logic implemented:
init.acl
function initialize() {
utils::initHooks();
initialize();
utils.acl
initialize callbacks to handle CMS session handle
function Callbacks() {
  sess_add_callback(SIM_SESSHDL, "checkin", "utils::checkin_callback");
  sess_add_callback(SIM_SESSHDL, "create", "utils::create_callback");
function checkin_callback(dobj, docid, ud) {
local firstoid = dobj_first_oid(dobj);
local checkindoc = oid_doc(firstoid);
graphicnumber(checkindoc);
doc_save(checkindoc);
  return 0;
function create_callback( name, folder, opts, first, last, version, objtype, ud ) {
    local doc = oid_doc(first);
  graphicnumber(doc);
  doc_save(doc);
  return 0;
function graphicnumber(doc)
// write your business logic to get windchill no
something like
local number = dobj_get_attr(imagedobj,"WC_NUMBER_ATTR");
0 REPLIES 0
