I have just upgraded to Arbortext 6.0 M010. We use an aliasFilePrintPreview command to execute an ACL script when the Print Preview icon is clicked on the Edit toolbar.
This all worked great in Arbortext 5.x. I have checked the editmenu.cf file to make sure that I have the correct command for Print Preview and I have also check the editwindow.xml file to verify the toolbar command. It still says FilePrintPreview.
If I modify the editwindow.xml file to execute the script it works fine but that will change it for the entire application and I need it to be doctype specific. I have also tried to alias the id Toolbar_Preview but still no luck.
Any suggestions would be greatly appreciated.
