18-Opal
Jan 31, 2011 11:52 PM UTC
Using fo:instream-foreign-object to create an svg ellipse around a step number
Hi Kathy-
From the annotated version of the XSL support document in the Arbortext
Help Center:
6.6.6 fo:instream-foreign-object
Arbortext software does not support this extended-level formatting
object.
Sorry. You might have better luck if you save the SVG as an external
file and reference it as an external graphic.
--Clay
    Jan 31, 2011 11:55 PM UTC
    Itseems easy to usesvg withininstream-foreign-object to create an ellipse around a step number in XSL FO. However, Arbortext publishing engine seems toonly publish the svg text element with the step number and I'm not seeing any attempt at the svg ellipse. I can make this work in another rendering tool. It's entirely possible that the other tool I'm using to test my XSL FO just renders the svg ellipse differently -- so perhaps the size and coorinates just happen to work foranother renderingtool, but are not correct within thearbortext interpretation **OR** Arbortext just doesn't do svg other than the text elementin instream-foreign-object. Does anyone know if svg in instream-foreign-objectis supposed to work?
    <fo:instream-foreign-object< font="> content-height="10pt">
    <svg:svg< font="> xmlns:svg="http://www.w3.org/2000/svg"
    height="50" width="150" viewBox="0 0 100 50">
    <svg:circle< font="> r="50" fill="red" stroke="black" stroke-width="3"/>
    <svg:ellipse< font="> cx="25" cy="25" rx="40" ry="25"
    fill="none" stroke="black" stroke-width="3"/>
    <text< font="> x="10" y="40" font-family="Arial" font-size="50" fill="black" >
    <xsl:number< font="> count="crewDrillStep" level="any" from="crewDrill|subCrewDrill" format="1."/>
    </text>
    </svg:svg>
    </fo:instream-foreign-object>
    Thanks in advance,
    Kathy
    Feb 1, 2011 12:08 AM UTC
    The whole graphic for every possible number in every possible font size is
    exactly what I wanted to avoid. Too bad, so sad.
    Kathy
    Feb 1, 2011 12:48 AM UTC
    What font sizes are possible? How does the ellipse differ for
    different font sizes and different numbers? What sort of FO code
    surrounds the number and ellipse (e.g., a table)? It might be
    possible to have a limited number of variants of the ellipse and
    overprint it with the number.
    -Brandon 🙂
    Feb 1, 2011 12:53 AM UTC
    Kathy:
    What products/tech are you using? Styler? Publishing Engine? Print
    Composer? FOSI?
    Liz
    Feb 1, 2011 2:20 AM UTC
    Unicode contains a large range of circled numbers, perhaps you could use
    these? (I think there are quite a few fonts out there that support a good
    range of circled numbers)
    Unicode also has a combining "diacritic" that is a circle U+20DD
    18-Opal
    Feb 1, 2011 4:38 AM UTC
    Hi Kathy-
    Don't give up hope yet. If you're creative, you can probably set
    something up to do this as part of your publishing process. You're
    already generating the SVG, so just route it out to a file and then
    generate a reference to that file as an fo:external-graphic instead of
    putting it inline. Here's an XSL template that gives you a general sense
    of how this could work:
    <xsl:template match="graphic">
                    <xsl:document href="{some_generated_filename}.svg">
                    </xsl:document>
                    <fo:external-graphic src="{same_generate_filename}.svg">
    </xsl:template>
    Note that the <xsl:document> element is an XSLT 2.0 feature, so you'll
    need to set the version attribute on your xsl:stylesheet root element to
    "2.0". You might also have to do some tweaking with the path for the
    generated SVG file to make this work with PE.
    --Clay
