Using Arbortext Editor to edit an XML document, is there any way to edit the raw XML source as you work in Edit View or Document Map?
Alternatively (short of creating a new document), is there a way of changing the doctype or XML schema associated with the XML document?
We want to modify several existing "vanilla" DITA documents so that they are associated with a DITA specialization.
Cheers,
Tony
Tony Morales
Information Tools Architect
Oracle Corporation
500 Oracle Parkway
M/S: 4OP1126
Redwood Shores, CA 94065
