Warning/Error message help
cborresen
When publishing to PDF, I'll sometimes get an error/warning message (for example if I don't back up a keyref with an href), and the message gives me a line number (where the issue occured). Is there an easy way to search for that line from the bookmap? Currently, I'm searching for the concept id where the issue occurs manually, and it's a pain.
0 REPLIES 0
