XML line break and tab display issues - possible setting?
jfuller03
The tabs and line breaks in our XML are not being ignored and they display in Arbortext. Is there a setting to ignore the white space created by these line breaks and tabs? Our client sends us their XML which has no tabs or line breaks, we translate this and our application formats the XML in what we've known to be a standard tabbed format (other clients have no issues with this format although I don't know that they use Arbortext). Now when the client views the XML in Arbortext extra line breaks and spaces or tabs are added to the view although the only difference in the XML is the layout of the text. Is there a setting to ignore these line breaks and tabs in Arbortext or can it only accept similarly formatted XML? Here are some examples of the differences we see in the XML which results in display issues in Arbortext. Here is the client's XML.
fcfd693794
Here is ours.
fcfd693794
I'd show an image of the display issues but I don't have one available on the web to link to. Basically, what we are seeing is extra spacing being added in the table, after the table and also the color of one of the table cells does not show until we reformat the XML to match the English version. If there is a setting we can use to correct the display issues that would be ideal so we don't have to change each file's XML format manually or alter our application to accomodate this. Thanks for your help!
lfraley
6-Contributor
(To:jfuller03)
Are you pretty printing the XML before sending it back to the client?
