XUI and Java
niki_juhi
XUI and Java
I’m hoping to get some XUI and Java related guidance.
I want to populate a list control in a XUI dialog using Java. I don’t know which java object to use to manipulate the XUI dialog.
I’m planning to do -
Open XUI dialog from ACL.
When click the Search button on the dialog – A Java method (I’m thinking to pass XUI dialog ID and list box ID as arguments) is called that talks to the database and retrieves records from it based on information provided in the XUI dialog. I want this Java method to populate the list box with the retrieved records.
Any help will be greatly appreciated.
Thank you,
Niki Patel
0 REPLIES 0
