about the the Arbortext Programmer's Guide
pzorrilla
Hello Experts!
I was wondering where I can find and consult the Arbortext Programmer's
Guide? Could you please give me a link or directions in order to access
this content, it would be pretty useful for me! 😃
Thanks a lot for your help and support.
Paulette Zorrilla
Hi Paulette--
It should appear in your copy of the Arbortext Help Center. In Arbortext, select Help->Help Center from the menus. In the Table of Contents, there will be a top-level section called Programming. Inside there is lots of good stuff, including the Programmer's Reference.
--Clay
Clay Helberg
Senior Consultant
TerraXML
1380 Forest Park Circle, Suite 100
Lafayette, CO 80027
OMG!! I found it 😃
Thank you very much!
Regards...
Paulette Zorrilla
There is some good information in there and I AM NOT a programmer, but use
it routinely.
Another way to see how things in Epic work is to look into the various files
(other than the .exe files) and see how they get things done. This is
especially true for ACL coding.
Lynn
And don't forget the adepters wiki at:
