acl.DOMOID
samah
acl.DOMOID
We have a .NET application that accesses the Arbortext DOM through the
API. We access nodes in Arbortext using
Epic._Application app = new Epic.ApplicationClass();
Epic.DOMDocument doc = app.ActiveDocument;
Epic.DOMElement el = doc.GetElementById(InstanceID);
But we ran into that some nodes do not have unique ID attributes so
instead we'd like to use a node's OID to retrieve a node, I'm trying to
use.
Epic.Acl acl = app.Acl;
Epic.IDOMNode Aomtemp = acl.DOMOID("526");
Where "526" is an oid of a node in an open AT document
But I get the exception:
"Error HRESULT E_FAIL has been returned from a call to a COM component."
Can somebody help me with that?
Samah
samah
(To:samah)
Hello all,
I figured this out, I was using a wrong oid, it should be Epic.IDOMNode
Aomtemp = acl.DOMOID("(526,1,29)");
Now I have another problem, Arbortext is passing the "oid" to the
external .Net application and then it freezes until the .Net application
shuts down. How can I make Arbortext pass the oid, lunch the .Net
application and regain control and not freeze.
Samah
bibach
(To:samah)
Samah,
I think we need a little more information about your application. I've gathered that you're invoking it from within Editor, but how are you invoking it? What is your intended mode of interaction? Is it a dialog that is supposed to remain open and continue to interact with the Editor while also allowing the user to interact with the Editor directly?
-Brandon 🙂
samah
(To:samah)
Brandon,
I figured it out 🙂 Thanks!
Yes. The .Net application is invoked from within editor, the editor
passes the "oid" of a node to the external application then the
application uses acl.DOMOID("oid"); to get the DOM Node. I needed the
editor to pass the oid to the application and stay responsive to other
actions, in the editor when I changed the code that lunch the external
application from Acl.func("system", "C:\\Program
Files\\JMP\\CIT\\InsertionTool.exe " + case_oid); to Acl.func("system",
"C:\\Program Files\\JMP\\CIT\\InsertionTool.exe " + case_oid + "&", 1);
I got the behavior I needed.
Best,
Samah
