adding custom menu and submenu items
ptc-1123085
Hello. I am trying to add submenu items to the Edit menu. I figured out how to add the items to Edit, but what I really want to do is to create an Edit menu item 'Block Selection' that has 3 submenu options (like Tools > Compare).
Here is a snippet of my existing code:
if( !menu_exists(".Edit.Block Selection") ) {
menu_add -before ".Edit.Delete Markup" "Block Selection &Start" -cmd {tigre::selectionStartSave();} -keytext "Alt+.";
menu_add -before ".Edit.Delete Markup" "Block Selection &End" -cmd {tigre::selectionStartSave();} -keytext "Alt+>";
menu_add -before ".Edit.Delete Markup" "Block Selection &Mark" -cmd {tigre::selectionStartSave();} -keytext "Alt+=";
menu_add -before ".Edit.Delete Markup" " -separator;
If you know the magic words to create submenus, please help! Thanks.
- karen dL.
6 REPLIES 6
function add_tools_create_change_bar_markup(){
#Tools Create Change Bar Markup
if(!menu_exists(".Tools.Create Change Bar Markup")) {
menu_add -menu -before .Tools.Spelling "&Create Change Bar
Markup"
The code above creates "Create Change Bar Markup" which is really a
sub-menu.
Hi Karen-
You want to use menu_add -menu to create your submenu, then add your
commands to that submenu. Something like this:
menu_add -menu -before ".Edit.Delete_Markup" "My submenu"
menu_add ".Edit.My_submenu." "Block Selection &Start" -cmd
...etc.
HTH
--Clay
Clay Helberg
Senior Consultant
TerraXML
Thank you both for your help, but I still am not seeing what I want to see.
whatI want is:
Edit > Block Selection > (Start | End | Mark)
what I get is:
Edit > (Start | End | Mark)
Currently, my code looks like this:
menu_add -menu -before ".Edit.Delete Markup" 'Block Selection';
menu_add ".Edit.Block_Selection" "&Start" -cmd {tigre::selectionStartSave();} -keytext "Alt+.";
menu_add ".Edit.Block_Selection" "&End" -cmd {tigre::selectionEndSave();} -keytext "Alt+>";
menu_add ".Edit.Block_Selection" "&Mark" -cmd {tigre::selectionMarkIt();} -keytext "Alt+=";
whatI want is:
what I get is:
Hi Karen-
The piece you're missing is a dot at the end of each of your menu paths in
your menu_add commands. So, your code should look like this:
menu_add ".Edit.Block_Selection." "&Start" -cmd
menu_add ".Edit.Block_Selection." "&End" -cmd
menu_add ".Edit.Block_Selection." "&Mark" -cmd
You have to look carefully to see it, but I've changed
".Edit.Block_Selection" to ".Edit.Block_Selection."
--Clay
Clay Helberg
Senior Consultant
TerraXML
Yay! Thank you. It works now. Whew.
- kdL.
