We jsut got an upgrade to Photoshop. Using the crop tool we crop images to 3.12 X 2.25, 300 dpi. When placing it into IsoDraw, it used to fit our template, now it is way oversized. See attached image the square in the middle is the template.
Bryon
I go between illustrator and ISOdraw and I have the same problem
This issue with jpgs has been corrected in Isodraw M040
Bryon
