I have no sucess in using the command line find to find an element with an attribute. Is this possible?
e.g. does not work, if I drop the attribute, of course it works. Is there some syntax that I can use?
find -m '<brk type="npg">'
"Experience is that marvelous thing that enables you to recognize a mistake when you make it again."
-Franklin P. Jones
