creating a complex index sort key using a padded article number
naglists
This was to make a field index that sorted on the document order of an
article. The sort key was complex, it was actually built up of
Section
Division
Article
Where some sections did not have Divisions, the articles were directly in
the Section. In other cases, the Articles were inside of Divisions inside
of Sections, so the ultimate sort-key was:
SSSS.DDDD.AAAA
A "real" one would probably look like:
0002.0004.0012
Or, Section 2, Division 4, Article 12.
Anyhow, this is the bit that padded the article number. Next comes the FOSI
fragment calling this function. Finally, the FOSI fragment where the entry
was added to the index.
function get_article_num_sort_key(win, oid) {
return reverse(substr(reverse('0000' .
oid_xpath_string($oid,'count(preceding-sibling::article)')),1,4));
<att>
<fillval attname="my_fosi::get_article_num_sort_key" attloc="system-func"&lt;br"/>fillcat="savetext" fillchar="conrule">
<charsubset>
<savetext textid="article_num-sortkey.txt">
</charsubset>
</att>
<savetext textid="field-index.app"&lt;br"/>conrule="<ixpt>,number_fld-value.txt,</ixpt>,<ixkey>,number_fld-sortkey.txt,\
\,article_num-sortkey.txt,</ixkey>,<ixsub1>,name_fld-value.txt,</ixsub1>,<ixsub2>,change_fld-value.txt,</ixsub2>,<ixsub3>,description_fld-value.txt,</ixsub3>,<ixsub4>,article-no.txt,</ixsub4>,<ixpgstr>,bodyfolio,</ixpgstr>"
placemnt="after" append="1">
Paul Nagai
0 REPLIES 0
