I happened to mention your request to the lead developer for Styler and
he came up with a really neat trick.
First, create a new empty stylesheet for an example document in your new
DTD. Second, use the Add New Elements... Dialog (under Elements in 5.3)
to add all of the declared elements from the DTD as unstyled elements in
the new stylesheet. Last, add your existing stylesheet as a module to
this new stylesheet.
Assuming that all goes correctly, you should now see 1 or 2 entries for
each element.
If 2 entries, then this element was there in the old stylesheet and is
still there in the new DTD.
If 1 entry and it is has a module name, then it is from the old
stylesheet but there is no match in the new DTD.
If 1 entry and it is unstyled with no module name, then it is defined by
the new DTD but not there in the stylesheet.
John Dreystadt
Software Development Director
Arbortext - PTC
734-352-2835
