get_user_property function
carolynherlin
I have a user-defined option in the Preferences dialog box that writes a value to the epic.wcf file. The entry in the epic.wcf file looks like this:
<properties>
<property>
<name>Application1Preference1</name>
<value><string>false</string></value>
</property>
I want to be able to read the value of the <string> element from another .acl file and act on it depending on whether the value is true or false. I'm guessing that I need to use the get_user_property function, but I'm not sure how to use it. Specifically, I don't know what to put as the key. Can anyone enlighten me?
Carolyn Herlin
Hi Carolyn—
The online help for this function seems pretty straightforward. The key should be the name you’ve assigned to the property, viz. the content of the <name> element in the <property>. Try this:
$pref1 = get_user_property(“Application1Preference1”);
if ($pref1 == “true”) {
# do something
else {
# do something else
HTH.
--Clay
Thanks, Clay.
I just thought that I needed to put something more complicated as the argument for get_user_property. Just putting Application1Preference1 worked. I didn't realize it was so simple.
Thanks again.
Carolyn
