I'm working with a new dtd (38784LEG-BV6a) supplied by a customer and I just began inserting the newly finalized graphics into the sgml file and am experiencing some odd behavior. When I insert the graphic element (I have the browser set to search the graphics path which is a network directory), I select the file, hit OK and it inserts the file but always adds the text "graphic" in front of the filename. In other words, if I select the file "fig1-1.eps" from the repository, it inserts the tag <graphic boardno="graphic23-1-011"> in the text and the notation in the header of the file reads: .
Why is it doing this? and is there a way to make it stop?
K McCain
Ed,
Yes. I've determined that is exactly what it is doing. Some of the graphics have names that begin with an alpha and some are purely numeric so everything was going fine until I hit those numerically named graphics and then I got confused because it was inserting the extra text into the entity name. I suppose as long as the filename is correct it will work.
Is there a different way that I should be entering them? I've seen discussions here about entity vs filename methods but I'm pretty new to Arbortext. I've tried reading the online documentation about this, and it just wasn't clear to me.
KM
