Hello, I am having a problem with menu customization with ACL. To add specific menus I try to detect some menus, I am using their names for exemple "File", or "Tools". But when the system is in another regional setting, for exemple in French, spanish, "File" or "Tools" are changing to the french of spanish corresponding values, so my tests in other languages are not valid. Do you know if there is a way to detect each menu with identifier instead of theirs names? ( maybe with corresponding entities? ) If yes do you know where I can find the list of entities for each existing menu? ( just for info, I would like to avoid use on environment parameter to force Arbortext to work in english ) Thanks a lot
