Hello everyone,
I need to make some modifications to scripts found in the%ARBORTEXT-INSTALL%\adapters directory. Typically, you can copy the OOTB scripts into the custom folders without having to modify the original. However, this folder doesn't seem to work the same way. I can certainly modify the originals, but that would mean replicating the modifications on every client.
Is it possible to replicate these scripts from adapters in the custom folders?
-Jeff
