"Flattening" a DTD
Good Morning!
Haven't seen anything even close to this one:
Most of our DTDs have a significant portion of their content in entities (in some cases, all but the root element). This promotes, of course, the use of the same structure for a given purpose across all doctypes.
Our problem is, when we deliver data, we deliver a copy of the then-current doctype DTD as well. This means someone must gather up copies of all the needed entities, as well as the main doctype file. That has proven to mildly error-prone.
We tested using Architect or Editor to flatten the entities ('doc_flatten all'), but without success. The former has no Command Line in the requisite window, and the latter insists on loading a DTD as an ASCII file, in which case 'doc_flatten' has no effect.
Thoughts? Ideas?
Thanks in Advance,
Steve Thompson
TAD Technical
Boeing-IDS Technical Publications
+1(316)977-0515
MC K83-08
The truth is the truth even if nobody believes it, and a lie is a lie even if everyone believes it.
NOTICE: This communication may contain proprietary or other confidential information. If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this e-mail in error, and delete the copy you received. Any and all views expressed are the current understanding of the sender and should not be interpreted as an expression of official Boeing Company policy or position.
Les renseignements contenus dans ce message peuvent être confidentiels. Si vous n'êtes pas le destinataire visé ou une personne autorisée à lui remettre ce courriel, vous êtes par la présente avisé qu'il est strictement interdit d'utiliser, de copier ou de distribuer ce courriel, de dévoiler la teneur de ce message ou de prendre quelque mesure fondée sur l'information contenue. Vous êtes donc prié d'aviser immédiatement l'expéditeur de cette erreur et de détruire ce message sans garder de copie.
Thoughts? Ideas?
Thanks in Advance,
Steve Thompson
TAD Technical
+1(316)977-0515
MC K83-08
