retrieving an option setting?
ptc-953343
In ACL I do this to get the user value set in change tracking:
$user = option("user")
I'm trying to get to the same value in Javascirpt, so I tried this:
var $user = Acl.eval(option("user"));
and then this:
var $user = Acl.execute(option("user"));
In both cases Java console shows
"ReferenceError "option" is not defined. Is there another way to get
to the options from Javascript?
thanks
..dan
Hi Dan--
You need some extra quotes there. The Acl.eval option expects a string argument, which it passes to the ACL interpreter. Try this:
var user = Acl.eval("option('user')")
Or, you just could use the standard Application.getOption(), like this:
var user = Application.getOption("user");
--Clay
Sorry, took a second look at the examples and I needed some
additional quotes, so this works:
var $user = Acl.eval("option('user')");
..dan
Thanks, just discovered the quote issue, thanks for the getOption lead.
..dan
