Michiel,
I am not trying to be smug, but I think iti s called normal operation.
Basically Epic does not display anything prior to the first tag in the document. So anything from
Here
[Any local entities]>
To here
<testcase>
will not show up on screen.
If you search for processing instructions, you will not see these. If you do an ACL command like 'eval oid_name(oid_first())" you will see the top level tag. Actually, the PI outstide the declaration subset may appear, but anything prior to or inside the declarataion subset will not show up.
Lynn
http://appcmsp:28879/dtdexpand/sl_comment.dtd" [
the 2 process instructions before the doctype declaration are not
visible in Epic.
If I have the same construction without the subset-declaration [], the
process instructions become visible:
http://appcmsp:28879/dtdexpand/sl_comment.dtd">
What's the reason for this strange behavior?
Kind regards,
Michiel Vanhoutte
Wolters Kluwer Belgium
>> To unsubscribe from the list, send an email to listmanager@maillist.arbortext.com with the following in the body: unsubscribe adepters - For additional information on the adepters list (how to subscribe or unsubscribe etc), send an email to: listmanager@maillist.arbortext.com with the following in the body: info Adepters - You may also go to forums.arbortext.com, enter the Adepters folder and change your subscription options and preferences.>>
