tag_display behavior different from ACL than from command line
naglists
I am issuing the following command:
tag_display -local -icon
From both the command line and from within an ACL looping over content and
choosing specific oids.
The element is collapsed and represented by the barbell icon 100% of the
time when I issue this command from the command line with my cursor in the
tag.
When issued from the ACL, the command works as expected unless the tag in
question has child elements.
For example:
<para>Blah blah blah.</para>
Is always iconized.
<para>Blah blah blah <bold>BLAH</bold>.</para>
Is only iconized from the command line. It is NOT iconized from the ACL.
Anyone seen this behavior before? Is it "as designed" or is it a bug of
some sort do ya think?
Paul Nagai
I got it. My ACL was looping using oid_forward(). Which is correct EXCEPT
when I collapse. Immediately after a collapse, I need to oid_next(). Derp.
On Tue, Sep 16, 2014 at 3:11 PM, Paul Nagai <->
wrote:
> Hi,
> tag.
> For example:
> Is always iconized.
> Paul Nagai
