toolbar geometry
BrianJ
toolbar geometry
I've been customizing Arbortext Editor for clients for over 6 years now
and I've never been able to figure this out.
We have several custom toolbars. I understand that toolbar location
config info is saved automatically by Arbortext on close to a wcf file.
However, there are times when those settings aren't remembered the next
time an editing session is started. I could live with this. The more
annoying problem is when a user opens Editor and the toolbars are fine
(where he set them the last session), but then he opens a 2nd document
(both the same doctype) and the toolbars are off. As in a toolbar that
should be aligned to the left now begins about mid-window, pushing any
other toolbars on that toolbar row even further right. Sometimes a
toolbar will be kicked off to a row by itself.
Am I missing something? Does anyone have any tips on how to keep the
toolbars in the locations the user sets them?
Brian Jensen
bjensen@bluelid.com
Are you sure that the user has only one .wcf file? This sounds as if there may be multiple .wcf files. On a command line in each opened document try 'eval $APTPRFWCF' to verify that all document instances see the same .wcf file.
Arbortext will write a .wcf file in the current document directory unless the APTPRFWCF environment variable is set to ensure a consistent location.
Hope this helps.
David
David S. Taylor
Project Manager, Structured Information
Institute for Research in Construction
National Research Council Canada
Bldg. M-23A, Room 239
1200 Montreal Road, Ottawa, ON K1A 0R6
