using javax.xml.* with AE 5.3 M020
ToddHicks
I see where the JRE for 5.3M020 is 1.5.0_11. We want to start using
javax.xml goodies. I'm not sure what JRE is on the Citrix boxes we have
Arbortext Editor running on.
I have the impression that it doesn't actually matter - that Java called
from ACL is running in Arbortext Editor's memory space, and is using the
Java engine that ships with Arbortext Editor. But I admit it, I am
pretty green when it comes to Java, and I have this feeling like I don't
really get it. Are we concerned more with the JRE, or the JVM?
Q: Can we fire off Java code that imports javax.xml? Or to put it
another way, what do we need to do in order to make that possible
besides actually having the javax.xml jar in our classpath?
Todd Hicks
Manager, Editorial Desktop - Content Technology
Wolters Kluwer Global Platform Organization
(415) 785-4546 (Office)
todd.hicks@wolterskluwer.com
<blocked::<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:todd.hicks@wolterskluwer.com">">mailto:todd.hicks@wolterskluwer.com>
Hmm,
There may be an easier answer than this, but you can always put any jar in:
custom\classes
Alternately, you can specify a separate JVM by putting a directive in an acl
file in custom\init that reads:
set javavmpath="C:\JVMDIR\jvm.dll"
Though I'd be cautious about the second one, since I'm not sure how well
newer JVM's would play with the built-in Arbortext libraries.
keith
On Wed, Aug 20, 2008 at 11:24 AM, Hicks, Todd
> I have the impression that it doesn't actually matter – that Java called
> Java engine that ships with Arbortext Editor. But I admit it, I am pretty
> green when it comes to Java, and I have this feeling like I don't really get
> Q: Can we fire off Java code that imports javax.xml? Or to put it another
> way, what do we need to do in order to make that possible besides actually
> Todd Hicks
> *Manager, Editorial Desktop - Content Technology **
> Wolters Kluwer Global Platform Organization*
Hi Todd--
I think the javax.* hierarchy should be available with stock 5.3. At least with 5.3 M030, I can call javax.xml.parsers.DocumentFactory.newInstance() and it works just fine. So, before you spend a bunch of time trying to jerry-rig an alternate JVM, just try your code with the standard JVM and it will probably work OK, unless you are specifically using classes or methods that you know were not introduced until after Java version 1.5.
--Clay
Thanks Keith and Clay! Digging in now ...
