xui tabpanel: can I force one other than the first to be "selected" on window load?
naglists
I set an id on tabpanel and then try to;
dlgitem_set_focus($win, "mytabpanelid");
dlgitem_display($win, "mytabpanelid");
dlgitem_set($win, "mytabpanelid","ACTIVE",1);
dlgitem_set($win, "mytabpanelid","VISIBLE",1);
But no joy. The functions all return 1 but the first tabpanel in the series
is actually "selected" or displayed or "on top" if you know what I mean NOT
the one I'm attempting to call via its id.
Paul Nagai
5 REPLIES 5
Hi Paul-
Try setting focus to a control *on* the tabpanel rather than the panel
itself.
--Clay
tfu1
(To:naglists)
Paul,
If the id of the tabbox is "tabbox" and you want to select the second
panel, try dlgitem_set_value(win, 'tabbox', 2);
Yes, I know that this is hard to figure out.
Tung
dlgitem_set($clay,"beer","ACTIVE");
That did it. Thanks!
All of the sudden, I've got three choices. Thanks again, you rock!
dlgitem_set(win, 'tabbox','VALUE',2);
dlgitem_set_value(win, 'tabbox',2);
dlgitem_set_focus(win,'controlontabratherthanthetabitself');
Help on dlgitem_set_value states it is equivalent the the first example
above.
