Differences in speed for different Pro/e licenses? answer found read here...
Newbie
How are you invoking the other licenses?
from the words of Bill Kunz...
""If you are using the Define Command feature in Ilink your other
licenses are
starting in the win32gdi mode not opengl.
If you have defined these startup commands in Ilink you need to append
-gSmiley Surprisedpengl to the start up command. See example.
d:\ptc\proewildfire\bin\proewildfire.bat -gSmiley Surprisedpengl
This is a bug in Ilink that is still not fixed in M021.
Bill Kunz
MCAD Specialist
Alcon Laboratories, Inc.
(949) 753-6709
william.kunz@alconlabs.com""
Alfonso Medina
Mechanical Design Engineer
ISE Corporation
7345 Mission Gorge Road, Suite K
San Diego, California 92120
(619) 287-8785 x-151
Fax: (619) 287-8795
www.isecorp.com
