Multiple BOM Balloons
Newbie
Is it possible to show multiple balloons on drawing? i.e. if a component is
repeated in assembly for 10 times, and I want to show 10 balloons at 10
different locations.
Best Regards,
Girish Kulkarni
RE: Multiple BOM Balloons
There are two option that you can show multiple balloons.
1. When selecting table region select with QTY. after you create the
balloons split them.
2. Second option After you create the balloons select again create
balloons. you will receive a Warning - select YES>
Good Luck.
Elkan
