adding assembly constraints using ProAsmcompConstraintsSet()
Newbie
Hi Guys,
I am facing some difficulties in adding constraints to the assembly component using API ProAsmcompConstraintsSet(). This API is available in Wildfire 2.0/3.0 only.
I am able to add the constraints using the same API if assembly reference is set to one of the assembly datum planes. But if I try to set the assembly reference to datum plane of some other assembly component it fails to do so.
How to add a constraint which has assembly reference set to datum plane of some other assembly component?
