doubt in wildfire2 weblink setting parameters.
Newbie
Hi folks
The programming code is return below and the red color fonts
indicates where I am facing an error.
MY USER DEFINED PARAMETER IS NAME WHICH IS STRING TYPE AND HAS A
VALUE JHON .
I WANT TO REPLACE JHON WITH MADHAVA THROUGH WEBLINK .
I am trying to control a user defined parameter (which is a string
type) through weblink in wildfire2
I HAD DEFINED THE valueType= document.pwl.PWL_VALUE_STRING;
The following code is working fine if my user defined parameter (which
is real number) through weblink in wildfire2.
I HAD DEFINED THE valueType= document.pwl.PWL_VALUE_DOUBLE;
The error is overflow;
I have the passed the required no of arguments but it says they are
overflowing.
if (Type=="340")
FilePath="D:\\TESTING\\ ";
FileName="340.asm";
alert ( FilePath);
alert ( FileName);
var openassy =
document.pwl.pwlMdlOpen(FileName,FilePath,false);
var ABC="MADHAVA";
if ( ABC != null && ABC
ItemType=document.pwlc.PWL_MODEL;
FeatureID= -1 ;
ValueType=
IntValue=parseInt(ABC);
FloatValue=parseFloat(ABC);
StringValue= ABC;
BoolValue=( ABC ==
"true") ?true : false;
alert ( "itmType :"
+ItemType + "\n" +
"FeatureID:"
+FeatureID + "\n" +
"ValueType
:" +ValueType + "\n" +
"intval :"
+IntValue+ "\n" +
"dblval :"
+FloatValue + "\n" +
"strval :"
+StringValue+ "\n" +
"boolval :"
+BoolValue + "\n" );
var
status=document.pwl.pwlParameterValueSet
(FileName,ItemType,FeatureID,"NAME",ValueType,IntValue,
FloatValue,StringValue,BoolValue);
alert(status);
DO I MISS ANYTHING WHILE I AM PASSING THE ARGUMENTS TO SET THE USER
DEFINED PARAMETER TO THE ASSEMBLY FILE.
Please let me know if I am missing anything while I am trying to set
the parameter.
Thxs in advance.
With regards
t.madhavarao
RE: doubt in wildfire2 weblink setting parameters.
HI TO EVERY BODY I GOT THE SOLUTION .
IT WAS JUST JUST ENETERING SOME ROUGH VALUES.
IN THE PALCE OF parseInt(ABC); AND parseFloat(ABC);
BY DEFINING LIKE THIS IN WILDFIRE 2
IntValue = -32;
FloatValue = -32;
STRING VALUE IS CHANGED
BUT THIS VIOLATES THE RULE WHICH IS GIVEN IN PRO-E DOCUMENTATION.
BUT IT WORKS PROPERLY WITH OUT ANY ERROR
WITH REGARDS
T.MADHAVARAO
Hi folks
VALUE JHON .
overflowing.
if (Type=="340")
FilePath="D:\TESTING\ ";
FileName="340.asm";
alert ( FilePath);
alert ( FileName);
var openassy =
var ABC="MADHAVA";
FeatureID= -1 ;
ValueType=
StringValue= ABC;
BoolValue=( ABC ==
alert ( "itmType :"
+ItemType + "\n" +
"FeatureID:"
+FeatureID + "\n" +
"ValueType
"intval :"
+IntValue+ "\n" +
"dblval :"
"strval :"
"boolval :"
var
alert(status);
the parameter.
Thxs in advance.
With regards
t.madhavarao
List name: -
You are currently subscribed to toolkits as: madhava@idolafori.com.
To unsubscribe send a blank e-mail to
For assistance, email us at - or find other
contacts at www.ptcuser.org/org/contacts.html.
PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER,
Inc.
Pro/ENGINEER is a registered trademark of PTC.
Message authors are solely responsible for the content of their posts.
