Add to project, ineligible object selected
davehaigh
One of our Product is giving this error when you try to add objects to a project.
[cid:image001.png@01D067C7.DE2E3F30]
I can add objects from a different Product to the project. So it's nothing to do with the project.
What permissions would cause this? Every user we have tried is getting the same error, even admin's.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh
(To:davehaigh)
I guess I should update this. Found the problem.
CS32686 says:
that in order to add objects to a Project, the Product has to grant Change Permissions and Read permissions on objects in Product/Libraries.
I had to add change permission to the product folder context where the files reside.
[cid:image002.png@01D0687F.E7E00D20]
After that everything works as expected.
We are likely going to have to go thru a bunch of products and libraries and add this permission.
David Haigh
