{Blank Subject 2007-09-10}
6kurniawan
pls unscribe my account
6 REPLIES 6
Just in case you guys don't know this there is a config option that allows
you to see the full path of your current working directory on the title bar.
So when you do use the backup command at least you can see where you are now
working. And yes you are not the only ones who have been hosed by this
properly working command!!! smile
display_full_object_path YES
Curtis Smith
Aida Corp.
All
Is there a config option to set the working directory on Proe startup?
Eric Henriksen
Entegee Engineering
Davenport Iowa
Here's a way without any config options:
1. Create a shortcut to your pro/e executable
2. Right mouse click and select "properties"
3. In the "Start in:" field, type in the path to your desired working directory. For example C:\Temp
4. Start pro/e and C:\Temp will be the working directory and if you have a config file in that directory, it will be read on startup also.
5. If you want, you can also set your config option file_open_default_folder to display your working directory on startup rather than say My Documents.
Nathan M.
ProUsers,
Sorry to bug you.
I guess I'm one of the two; stupid and/or impatience!
I have been receiving emails from members, but I can not send?
The emails I have been using look like they changed, they are/were:
What do I have to do?
Thank You, ......Dzi?kuj?
Gary L. Stasienko
MRI Division, Mechanical Engineering
PHILIPS MEDICAL SYSTEMS, INC.
Cleveland, Ohio, USA
Tel: 1.440.483.5426, FAX: 1.440.483.5728
E-mail: -
The information contained in this message is confidential and may be
legally privileged. The message is intended solely for the addressee(s). If
you are not the intended recipient, you are hereby notified that any use,
dissemination, or reproduction is strictly prohibited and may be unlawful.
If you are not the intended recipient, please contact the sender by return
e-mail and destroy all copies of the original message.
Does anyone know why my chamfer dims no longer appear as "dist x 45º"? Now all I get is the distance.
I've noticed this since updating to the latest build of WF2.
Thanx
Tony
Tony,
The default chamfer's now D X D instead of D X 45. It'll show up correctly if you select the D X 45 option.
Rich
