Breakout View
Frosty
2-Explorer
Breakout View
Does anyone remember how to create a Local Breakout View, in WF4.0?
highway45
(To:Frosty)
WF4.0 ?
You should ask this in the ProE (CreoElements Pro) Forum:
http://communities.ptc.com/community/creo-elements-pro
Best wishes !
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
Frosty
2-Explorer
(To:Frosty)
highway45,
I answered my own question this morning.
I simply went to the Proe Help Tab; clicked Detailed Drawings; Displaying Section of Views; To Display a 2D Cross-Section View.
It was very easy...I've created these types of Views numerous times before, I simply forgot how to get to that menu.
Thanks for responding though !
vnaik-2
(To:Frosty)
Hey Forest,
Right click on view and go to properties
Select Visible Area
Select Broken view in View visibility TAB
It should look like this...
Then Click on Plus sigh to add new view
Then select two lines/Edges to create a Broken Section.
Mritunjay
3-Newcomer
(To:Frosty)
You may RMB on the particular view to whom wish the break Select Visible Area, then Select Broken view in View visibility TAB.
you almost done, you may choose the line type for broken line under line style
