Changing measurement system
ptc-2619096
I am currently using the student edition of pro-e and I was wondering if it was possible to change the measurement system from metric to english and vice versa.
that is possible to change the units.. Edit -- Setup -- units--(select the units) -- done. Just ensure you are aware of the options. convert dim ( 1" = 25.4 mm) Interpert Dim ( 1" = 1mm) Chander
