Converting Creo files in .BIM file
blad
I have a model in creo and wanted to convert creo file in to .BIM file. Is it possible in Creo or I need to use some external converter? I searched online and found that Autodesk Revit can create .BIM files. Is that the only option we have.
Any suggestions will be greatly appreciated.
Thank you
0 REPLIES 0
