Copy Features
eaolsen
Copy Features
Awfully quiet for a Friday!
I am trying to copy a group of features. It would be an exact copy, using
all the same references. I would then change a few dimensions in the new
features to make them different than the originals. I thought that was what
the copy-paste thing was for but I can't get it to work like that. It wants
me to specify all new references. Any Ideas?
Erik
Eric,
Try to use copy special and uncheck the 1st box and check the last one.
Also you can use the old copy command edit:feature operations:copy then
copy same ref diff version
good luck.
David Blatt
954 658 0570
