Creating a column in the UITree
SRINIVASAN1
7-Bedrock
Does any one have worked with creating a column in the UITree "ProUITreeColumnCreate". I could not find any sample in the installer path.
Hello @SRINIVASAN1
You've done creating column in UI Tree?
If yes, what is the Name of the attribute window in which column should be added?
